98 tj 4.0L engine problems help!! - JeepForum.com
post #1 of 3 Old 07-02-2010, 09:17 AM Thread Starter
j3rs3yd3vil
ok so to start out my oil presure has been fluctuating from mid to extreme lows on the gauge.. And my idle sems weird to me idk if it's always been this low but it idles at 800 rpm... Ok so now to the main prolem, when I'm driving all the sudden my jeep starts making a loud popping noise and starts stalling so instinctivley I step on the clutch and give it more gas but it will not let me go anywhere and continues to violently pop until I pull over and give it a beather.. But now when I come to stops my idle drops to a near 200rpm!!! This is really freaking me out and this is my dd so I need it fixed.... I'm not an amazing mechani but somthing tells me it the computer or the exhaust is bloked?!? Please help....
,matt
j3rs3yd3vil is offline
post #2 of 3 Old 07-03-2010, 06:27 AM
RubiconBlack
Sounds like the exhaust could be clogged and/or the fuel pressure is dropping off. I had a truck that would backfire "popping" and stall on me due to the fact my pressure was too low for any power. Once the pump cooled a little it would be fine until it warmed up again. It was so bad I did even have power going down hill. I had to stop at a gas station and I kicked the crap out of the bottom of the tank. I didn't have any issues after that, but the pump was replaced. I have also worked on cars that would loose power after they had warmed up due to the cats being clogged. The easiest way to check for this is to pull the up stream O2 sensors out and then drive it again. Its loud but it allows the engine to get the exhaust out. When they are clogged they act like a exhaust brake. I would try getting the vehicle to act up again. Remove the up streams and then drive it again. Make sure to use heat on the Exhaust to help loosen the O2's. Sometimes the threads in the exhaust like to come out with the sensors. I have remove threads before and you can either try to tap them back or replace the exhaust and that would suck if the cats. weren't the problem.
RubiconBlack is offline
post #3 of 3 Old 07-03-2010, 01:21 PM Thread Starter
j3rs3yd3vil
thanks for the help I'll try this as soon as I get home, I also found out that my first cylinder does not fire at all in idle but when I give it some more gas it seems to kik in? Idk I also might check my crankshaft positioning sensor to see if that's causing any problems
engine , stalling
Engine Problems brunhean Engines & Drivetrain 7 02-17-2010 09:00 AM
More problems w/ engine bay Rokjeep Engines & Drivetrain 1 02-11-2010 07:10 AM
engine problems! help! Dutchie123 Engines & Drivetrain 9 11-13-2008 09:15 PM
engine problems tippmann243 Engines & Drivetrain 11 04-02-2007 07:04 PM
Engine problems.. BigYellaJeep Engines & Drivetrain 9 02-13-2006 06:23 PM
