98 tj 4.0 major power loss - JeepForum.com
post #1 of 2 Old 07-26-2011, 12:58 AM Thread Starter
creepyjeep420
i have a 98 jeep wrangler with the 4.0 inlne 6. i had trouble with it sputtering for a while. well i had to cut part of the pipe off my muffler due toi wrapping it around my rear axle 4 wheeling. the way i cut it off it burnt a fist size hole in my gas tank. so i replaced with a tank from a 97 i think. it was smaller and had one of the breather tubes in a diffrent spot (i think it was breather). so my sputtering quit for a little while but now when i crank it up it will hardly run if i can even get it to crank. it seem to sound pretty good but i have about 1/2 the power i usually have. my jeep has had wireing problems since i got it. turn signals, brake lights and now horn and windshield wipers. its like there mixed up. i turn my lights on and the windshield wipers come on! when i put one on the blinkers on both of them come on and blink.. the guy that had it before me put a pretty nice radio and speakers in. think that is what started all this. my check engine light has been on and off probally 50 times in the past year but hasent been on in a while. im stupmed right now, i can deal with the turn signals and stuff being messed up but i bought a 6cyl for the power and would really like it back. i had it out four wheeling the other day and had it leaning to the right pretty hard and noticed it started leaking gas. thats where i will start maby the ring on the gas tank has come loose . someone suggested fuel filter but idk where or if it has one. so if anyone knows a good way to flush out the fuel lines and check the filter (if it has one) also i have heard some thing about a sensor in the steering wheel but i have no idea what it does or what it does.
if anyone can help me on any part of this any suggestions would be awesome!
one last thing when my gas tank got burn through it caught on fire. didnt look like anything got burnt or messed up but thought i would throw that in there. thanks
creepyjeep420 is offline
post #2 of 2 Old 04-19-2012, 09:50 PM
dwampler07
I can't answer your loss of power problem but I think the problem that your having with your lights, windshield wipers, etc. is because of the multifunction switch. I just had problems with mine and disconnected the battery overnight and I think the switch reset. The lights, wipers, and everything are all wired through the switch and I think its a pretty common occurrence.
dwampler07 is offline
4.0 , power loss , wiring
04' Rubicon Loss of Power Major Misfire Tmsnake1 Engines & Drivetrain 1 03-14-2011 12:22 AM
MJ loss of power Nick_Knipp Engines & Drivetrain 0 01-24-2011 05:47 PM
Loss of power in 5.7 Wombat 43 Engines & Drivetrain 19 07-28-2010 08:11 PM
What causes power loss? dogbluedrummer Tires & Wheels 4 12-12-2007 01:53 PM
More Power Loss Squandith Audio, CB & Ham Radios, GPS, & Electrical 2 12-07-2005 01:08 PM
