98 JGC chugging problem - JeepForum.com
post #1 of 4 Old 10-18-2009, 09:34 AM Thread Starter
Profire73
OK I have a 1998 Grand Cherokee that has about 116,000 miles on it with the 4.0L. It is a 4x4 Larado Package. I recently had the muffler replace and after that i would drive it for about 5 miles and it would act like someone was turning the fuel on and off. I would lose all power and have to pull over and wait for it to go away. It would last about 15 minutes and you could smell a load of fuel until it went away. It would then run normal again until you drive if a couple of miles.
Now i took it back to the shop and they said i need a new converter. I took it back home and cut the converter out and put a straight pipe in. Still does the same thing. I checked the fuel pressure and it runs at about 47lbs so that should be good.
I am not sure what i am missing but i hear alot of people talking about either the TPS or AIC.....could either of these cause this problem? I am going to test the TPS (after reading the posts .25 - .50 volts i think). Any other ideas? It does only happen when warm and there are no exhaust leaks.
Thanks in advance.
Profire73 is offline
post #2 of 4 Old 10-18-2009, 11:26 AM
wheelin
make sure the muffler isnt plugged
wheelin is offline
post #3 of 4 Old 10-19-2009, 06:02 AM Thread Starter
Profire73
I am going to take the muffler off to make sure but I am kinda thinking that maybe its my Crank Sensor.
Cause the problem will go away and then reoccur in a matter of 15 minutes. I would think that if the muffler was clogged I would have the problem on more of a constant basis. But then again I am not a mechanic and that is why I am here picking everyone else's brain.
On another note: I do not have the O2 sensor that was in the converter hooked up right now......would this make it run like that? I thought it would just give me the check engine light and also i could see my fuel mileage go down. Is there another O2 sensor that could be doing this.
post #4 of 4 Old 11-30-2009, 06:08 PM
mrquazy
Any updates on this? I might be having the same problem..
mrquazy is offline
87 yj problem getbent666 Audio, CB & Ham Radios, GPS, & Electrical 0 08-29-2009 11:31 PM
'05 5.7L Chugging Sound xa310165 Engines & Drivetrain 5 03-11-2009 06:55 PM
Amp problem Th3 Cavalry Audio, CB & Ham Radios, GPS, & Electrical 10 11-26-2007 05:36 AM
Noise When Chugging Along When Giving It Gas pete1182 Engines & Drivetrain 1 11-28-2006 07:50 PM
Problem in 4 low 1966cj5 Tires & Wheels 1 03-30-2006 05:25 AM
