98 Jeep GC 5.7 not Idling - JeepForum.com
post #1 of 3 Old 05-09-2012, 02:32 PM Thread Starter
hawkrox09
So yesterday after getting off of work, I went to unlock my jeep with the remote lock and unfortunately it did not work. I had to manually unlock my jeep. After unlocking it, the alarm started going off until I was able to press the remote lock to get it to stop! Fast forward to this morning, and my Jeep wouldn't start. I tried two times and then on the third time the jeep started if i pushed in on the gas pedal. I revved it up a couple of times and then the jeep stopped running. I tried starting it again and the only way I could get it to start was if I put my foot on the gas pedal but still it won't idle if I let off the gas. I was curious if it was a fuel filter getting stuck or if it was an issue with my fuel pump? Thanks guys!
hawkrox09 is offline
post #2 of 3 Old 05-09-2012, 03:45 PM
LJameson
Iac. It's on the throttle body and it opens and closes a plunger to control the idle. Did the battery die? Because I know when the battery on my TJ dies it will do the same thing until I drive it around for a little bit and get the battery charged up.
BTW, unless you did a motor swap, you should have either a 4.0, 5.2 or a 5.9
1990 YJ
LJameson is offline
post #3 of 3 Old 05-20-2012, 10:45 PM
obfdcherokee
Sounds like a battery issue to me Chrysler products don't idle with dead battries.
obfdcherokee is offline
having problems idling jeepordie10 Engines & Drivetrain 4 03-19-2012 11:15 PM
Engine stalls while idling GlennG Engines & Drivetrain 5 01-05-2012 08:40 AM
idling problems Kedds Engines & Drivetrain 2 12-08-2011 09:52 PM
idling smooth then dies? pioneer1 Engines & Drivetrain 9 08-06-2010 06:50 AM
Wrangler dies while idling kywrangler23 Engines & Drivetrain 1 07-08-2010 11:27 AM
