'98 2.5L wants to stall in Idle - JeepForum.com
post #1 of 4 Old 05-23-2011, 06:28 AM Thread Starter
dubv72
I have a 1998 wrangler, 2.5L, manual. The jeep starts and idles fine. If I give it a little gas while in idle or put it in gear to drive it works fine. If I give it more than a little bit of gas while in Idle it will stall. Does anyone know what may be causing this?
dubv72 is offline
post #2 of 4 Old 05-28-2011, 05:34 PM
JoeyC88
Try removing the battery and then reconnecting it... Then just let her idle for about 5 minutes. Sometimes the sensors get out of whack if you had a dead battery or other problems electrically.
JoeyC88 is offline
post #3 of 4 Old 05-29-2011, 07:44 PM
HELLSUNICORN
Pull out the idle valve and clean it and the throttle body. Sometimes they get gummed up and cannot move fast enough to keep the Jeep from stalling at idle
HELLSUNICORN is offline
post #4 of 4 Old 05-31-2011, 06:20 AM Thread Starter
dubv72
Thanks for the responses. I did just recharge the battery so maybe that is it. I will try disconnecting it like Joeyc88 recommended first. If that doesn't work I will clean the idle valve and throttle body.
dubv72 is offline
gas , idle , stall
89 XJ Wants to stall at stops My1989Jeep Engines & Drivetrain 0 04-06-2011 09:16 PM
trys to stall while driving rabunjeeper Engines & Drivetrain 2 02-17-2010 05:35 PM
Sputtering or wanting to stall? JEEPBURGH Engines & Drivetrain 1 10-28-2009 07:48 PM
stall on steep incline? brinoff General Jeep & Off-Road Equipment 7 07-28-2007 09:37 PM
uphill stall? mike mcgovern Engines & Drivetrain 2 02-11-2002 11:43 PM
