97 zj jumpy when taking off - JeepForum.com
post #1 of 11 Old 04-12-2012, 09:15 AM Thread Starter
cjkish86
Hi everyone. this is my first post I've usually been able to find someone else post helpful but i couldn't find anything that exactly described my problem so here it goes.
i got a 97 zj 5.2 w/ 249 t-case. i want to say it has something to do with the transfer case or transmission but I'm not 100% positive. only when i take off from a dead stop its real jumpy/vibrates until I'm half way through 2nd gear. both axle are good checked for metal shards, clean gear oil, play in pinion's and checked all my u-joint on the drive shafts and everything is good.
how would i know if the transfer case is going out? what kind of symptoms would i have? i plan on swapping for a 231 once this t-case goes out as well. but i want to figure out this problem before anything.
if anyone can help that would be great. I'm trying to get her going as soon as possible. I'm missing out on too many trips as it is.
cjkish86 is offline
post #2 of 11 Old 04-12-2012, 10:38 AM
mdm
Farm Wheeler
Motor mounts
Transmission mount
Drive shaft
Welcome to the forum.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 11 Old 04-12-2012, 11:37 AM Thread Starter
cjkish86
alright thanks ill check the mounts. as far as the drive shafts should i have them rebalanced?
thanks again.
cjkish86 is offline
post #4 of 11 Old 04-12-2012, 11:44 AM
mdm
Farm Wheeler
thanks again.
u-joints
mdm is offline
post #5 of 11 Old 04-12-2012, 12:48 PM Thread Starter
cjkish86
what if its none of the above?
cjkish86 is offline
post #6 of 11 Old 04-12-2012, 12:50 PM
thirdeye
kinda sounds like the trans mount
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #7 of 11 Old 04-12-2012, 01:57 PM
mdm
Farm Wheeler
Then you start looking for other causes. Would you rather remove your transmission and rebuild it just to find out that it was the transmission mount?
mdm is offline
post #8 of 11 Old 04-12-2012, 02:06 PM Thread Starter
cjkish86
i already replaced my tranny mount a few months back. I'll double check everything just to make sure and replace my motor mounts. I'm sure they are pretty worn out.
but yeah hopefully that will be the worst of it.
cjkish86 is offline
post #9 of 11 Old 04-12-2012, 03:25 PM
mdm
Farm Wheeler
Don't overlook the "new" transmission mount just because you recently replaced it. "New" doesn't always mean "good".
mdm is offline
post #10 of 11 Old 04-13-2012, 08:51 AM Thread Starter
cjkish86
good point. yeah might as well change them all out. thanks again.
cjkish86 is offline
post #11 of 11 Old 04-15-2012, 01:01 PM Thread Starter
cjkish86
Replaced the motor mounts didn't make any difference. we put her on jacks to check for any bad noises coming from the tranny or t-case and there was a winding noise coming from the tranny. Weird thing was when we dropped it and took it for a test drive. The original problem didn't exist anymore but now when in park and reverse it feels like its in gear but doesn't move and in neutrial it drives. I'm pretty sure that means the tranny is going out
cjkish86 is offline
Shudder when taking off in 1st. skyjackedjeep Engines & Drivetrain 8 11-13-2011 09:58 PM
Taking a Trip... ZJ-Soldier General Jeep & Off-Road Equipment 0 02-21-2009 09:40 AM
jumpy idle JRocker Engines & Drivetrain 1 11-17-2008 06:34 PM
Taking on the Rubicon PH0T0 General Jeep & Off-Road Equipment 1 05-22-2008 05:50 PM
taking out carpet Maximummud General Jeep & Off-Road Equipment 3 06-18-2006 10:03 AM
