97 ZJ 5.2 front drive shaft replacement - JeepForum.com
post #1 of 3 Old 01-06-2013, 05:06 PM Thread Starter
mnkjoe
So as you guessed i have a 1997 Grand cherokee with the 5.2.
I was wondering if anyone has ny experience replacing these, i have a new one coming in the mail and will be replacing it.
I Know you remove the 4 bolts at the transfer case but but is that it?
Any knowledge on this would be greatly appreciated
Thanks for the help guys!
mnkjoe is offline
post #2 of 3 Old 01-06-2013, 05:31 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
4 bolts at the T-case and 4 bolts at the front Yoke flange. sometimes the flanges stick together a bit, so a small hammer helps to jar them loose. 8 bolts, should take 15 minutes to swap out.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #3 of 3 Old 01-06-2013, 06:03 PM Thread Starter
mnkjoe
Thanks for the response, i forgot to mention its a CV joint(the one with the rubber dust boot) which has the 4 bolts at the TC and 6 bolts in a circle at the other end.
mnkjoe is offline
drive shaft , grand cherokee , transfer case , u-joint
