97 XJ Cylinder miss #1--stumped - JeepForum.com
post #1 of 2 Old 06-25-2013, 08:50 AM Thread Starter
LtCdrLange
1997 XJ Cherokee
Hey guys/ladies, I have a 97 XJ with the straight 6 of course. well I've been having a cylinder 1 miss for quite awhile. I am an at home DIY mechanic and I must admit this has me stumped. I've replaced the cap, rotor, spark wires, Spark plugs, injectors, ign coil, new upper block gaskets. at this point i'm just leveled. I put over $700 in the past few months into my girl (granted at 231k alot of it was preventative maintenance). The only other thing I can think of for the misfire is bad valve, bad rings (doubtful, no smoke or elevated oil pressure), bad timing set. I'm basically looking for some input you guys might have into a new direction I can look into.
Thanks,
Richard
LtCdrLange is offline
post #2 of 2 Old 06-25-2013, 01:06 PM
jokerchief462
Pull the plugs while it is warm and do a compression check. Read what the spark 0plug color is telling you. Color pages in a Haynes Manual. From there you will know if #1 is healthy.
There is a plug chart on this link.
http://www.mazdaforum.com/forum/mazd...n-31499/page2/
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
