97 tj cutting out under heavy throttle - JeepForum.com
post #1 of 2 Old 05-12-2014, 05:30 PM Thread Starter
jpedraza3538
Recently had to fix the sending unit on my 97 Tj 2.5. Pump wasn't sealed to the unit properly. Fixed that and it runs better but still cuts out under heavy throttle low rpm. Has new o2 sensors, plugs wires cap and rotor, ignition module, all the throttle body sensors are new. Fuel pump is set up properly now. Have only been able to drive it a couple miles since the fix. Is it cutting out because the ECU is still re-learning or what? Any guidance on this matter will help
jpedraza3538 is offline
post #2 of 2 Old 05-13-2014, 04:05 PM
hampton_b
Ignition module? Do you mean the ignition coil? What is the fuel pressure at?
hampton_b is offline
