97 jeep missing - JeepForum.com
post #1 of 9 Old 09-24-2012, 05:06 PM Thread Starter
mohr773
97 jeep missing
I have changed wires plugs, upstream and down stream oxygen sensors the sensors was because of the codes the plugs and wires for good measure and it still seems to be running rich any suggestions?
mohr773 is offline
post #2 of 9 Old 09-24-2012, 06:56 PM
r0b0
Throttle position sensor possibly? Or injectors?
r0b0 is offline
post #3 of 9 Old 09-24-2012, 07:01 PM
Joe-4
Let me know what you find out. My 97 is doing the same.
Joe-4 is offline
post #4 of 9 Old 09-24-2012, 09:02 PM Thread Starter
mohr773
I forgot I changed the throttle position sensor first
mohr773 is offline
post #5 of 9 Old 09-25-2012, 06:11 AM
pshivers
2008 KK Liberty
What are your long term and short term fuel trims at idle and around 2000 rpm?
pshivers is offline
post #6 of 9 Old 09-26-2012, 08:56 PM
r0b0
What the **** does that mean?
r0b0 is offline
post #7 of 9 Old 09-27-2012, 07:12 AM
pshivers
2008 KK Liberty
You said you changed the O2 sensor because of "codes". Using a scan tool, are the O2 sensors functioning now? Did the codes come back? Do they transition lean to rich? Is the upstream sensor stuck lean or rich? What are the short and long term fuel trim numbers doing in response to the O2 sensor signals?
pshivers is offline
post #8 of 9 Old 10-06-2012, 12:40 PM
Joe-4
I just changed my check valve and it fixed the jeep from missing and running rich.
Joe-4 is offline
post #9 of 9 Old 10-06-2012, 01:42 PM
stephenpetrilak
I have a 97 jeep doing the same thing missing n stalling I think I solved the problem change your idle air control valve clean the port n throttle body with gum out carb cleaner put back together If its dirty it telling the comp it not getting enough air good luck mine is running fine so far
stephenpetrilak is offline
