96 Jeep Laredo - JeepForum.com
post #1 of 9 Old 07-28-2013, 09:56 PM Thread Starter
TheAron67
96 Jeep Laredo
I just bought a 1996 Jeep Grand Cherokee Laredo with a replaced long block 4.0 straight 6 cylinder and when I crank it up, until it warms up, it loses power and skips kinda like if you stall out in a stick shift. Ive replace the plugs and wires, cap and rotor, the fuel pump, fuel filter and put BG 44k in my gas tank and Idk what to do. Any Ideas?
TheAron67 is offline
post #2 of 9 Old 07-29-2013, 04:52 AM
Holder350
1995 XJ Cherokee
You have a part that has what is know as thermal failure, which means it works good untill it gets hot.
Most likely culprit is the CPS
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 9 Old 07-29-2013, 05:14 AM Thread Starter
TheAron67
It works good once it has warmed up but it feels like it skips and stalls about 30 seconds after I crank it up, only when I first crank it up. Once it gets warmed up its fine
post #4 of 9 Old 07-29-2013, 05:57 AM
Holder350
1995 XJ Cherokee
Sorry I miss read that
Sent from my phone
post #5 of 9 Old 07-30-2013, 07:12 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Try this. Turn the key on, then off 2 or 3 times before going to Start and see if it fires up better.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #6 of 9 Old 07-30-2013, 07:37 AM Thread Starter
TheAron67
I tried it and it fires up wayy faster and it doesnt skip like it normally does
post #7 of 9 Old 07-30-2013, 07:38 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Fuel pump check valve is bad. You can learn to live with it or replace the fuel pump.
post #8 of 9 Old 07-30-2013, 08:01 AM Thread Starter
TheAron67
So Id have to replace the fuel pump?
post #9 of 9 Old 07-30-2013, 06:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pretty sure.
