96 country overheating - JeepForum.com
post #1 of 5 Old 05-20-2012, 03:32 PM Thread Starter
Aleshiamarie
My jeep runs and drives like a dream but its overheating while in idle and cools down while driving. I just replaced the thermostat so that wasnt the prob...fans work and nothing leaks all fluids look perfect as well.
Aleshiamarie is offline
post #2 of 5 Old 05-20-2012, 03:37 PM
WindsorRenegade
I wonder if your water pump is crapping out on you , or the drive belt is loose. Ever notice any squealing from the belt?
You did say no leaks, but are you absolutly certain? If the water pump is going out, there is a tiny weep hole in it that should be dripping anti freeze. It could be a small amount you just arn't seeing.
Someone, MUCH more knowledgable than me will be along shortly, I'm sure. lol
Welcome to the forum!
Originally Posted by ruthole View Post
I just bumped it around till it was in the hole and she went right in. But my hands were hard to fit in there.
WindsorRenegade is offline
post #3 of 5 Old 05-20-2012, 03:44 PM Thread Starter
Aleshiamarie
Lol thanks no squealing and im not 100% on the leaking I havnt seen anything yet
post #4 of 5 Old 05-20-2012, 03:49 PM
blubullett
1995 XJ Cherokee
If it cools while driving and overheats while idling then your problem is airflow. I would look into a new fan clutch. When they go out they cause you to overheat at idle because they aren't pulling as much air as they are supposed to.
NAPA part number 272310 is an upgraded one that will pull more air then the factory. Do your self a favor and don't tell them what it is for just ask for the part number. The counter jockeys will tell you it doesn't fit but it fits fine.
blubullett is offline
post #5 of 5 Old 05-20-2012, 06:15 PM Thread Starter
Aleshiamarie
Will deff do that...thanks
