95 ZJ 318 stalls/dies when stopping - JeepForum.com
post #1 of 8 Old 02-25-2014, 06:46 PM Thread Starter
zjfisher
I just bought a 95 ZJ with a 318 and 186k miles. I've noticed that it stalls when stopping and occasionally dies as well. The RPMs drop to about 250 when stalling but then just before stopping RPMs will increase to around 750 and it will jump. Is it possibly the torque converter? I also noticed that the transfer case grinds gear when going from neutral into 4AT (Quadratrac) like a missing synchro in a manual trans. has anyone had the same issues? any advice would be greatly appreciated!
zjfisher is offline
post #2 of 8 Old 02-25-2014, 10:02 PM
jnicewan
Torque converter is possible (ck trans fluid level) but I would check a couple other more common things first, like the IAC and vacuum lines. Other than a can of carb cleaner the IAC and throttle body cleaning is free and its best to remove the IAC for cleaning. Check vacuum lines and gasket areas for vacuum leak by spraying carb cleaner around them with engine running and pay attention for idle to change. When you clean the throttle body & IAC, go ahead and disconnect the battery negative cable, this will reset the PCM so it can relearn its base idle strategy with clean components.
jnicewan is offline
post #3 of 8 Old 02-26-2014, 12:26 AM Thread Starter
zjfisher
Thank you, I will try that.
zjfisher is offline
post #4 of 8 Old 03-06-2014, 12:55 AM Thread Starter
zjfisher
Unfortunately no luck on those three, the IAC wasn't terribly dirty and there was no change in idle for all the vacuum lines I could find. Does anyone know where the 318 is supposed to idle? Does anyone also have any other suggestions?
zjfisher is offline
post #5 of 8 Old 04-22-2014, 04:07 PM Thread Starter
zjfisher
Well I finally was able to replace the TPS to no avail. I am going to try the IAC next and hope for results.
zjfisher is offline
post #6 of 8 Old 08-22-2014, 04:15 PM Thread Starter
zjfisher
I haven't replaced the IAC, but I did replace the EGR transducer and voila! There's no more stalling and it runs better than ever! I also replaced the PCV and PCV hose, and the crankcase breather and 20 year old grommet which was hard as plastic.
zjfisher is offline
post #7 of 8 Old 08-23-2014, 12:02 PM
scottyjeep
How did you figure out that it was the transducer that was at fault?
scottyjeep is offline
post #8 of 8 Old 09-03-2014, 08:54 PM Thread Starter
zjfisher
I didn't. I read somewhere that the transducer was the component of the EGR assembly that most often failed. Since it was only $14 I thought it was a good place to start. However, I got a bad MAP sensor trouble code today. It died and sputtered and made odd sounds
zjfisher is offline
grand cherokee , stalls , torque converter , zj
