95 yj high oil pressure - JeepForum.com
post #1 of 4 Old 05-27-2013, 09:57 PM Thread Starter
95White_YJ
So did an oil change the other day and now I'm getting an extremely high pressure reading while cold once the motor fully warms up its goes back to normal. Any thoughts? I'm thinking the pcv valve needs to be changed and the hoses need to be cleaned out do to sludge. Thanks for your input
95White_YJ is offline
post #2 of 4 Old 05-28-2013, 07:47 AM
Newtons3
Newtons3's Avatar
It's not your PCV. What oil, etc. did you use?
Newtons3 is offline
post #3 of 4 Old 05-28-2013, 10:58 AM
rjbruzan
You probably hit the oil pressure sending unit while changing the filter. Either the connection is loose or the unit is going out. They are under 30 bucks and easy to change out.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 4 Old 05-28-2013, 11:13 AM
BIGBADWOLF
Check it again in a hundred miles or so. Polymers (viscosity improvers) in new oil take time to relax, Like a new polyester shirt....give it time
BIGBADWOLF is offline
