95 wrangler stalls when idling/coasting - JeepForum.com
post #1 of 3 Old 06-28-2010, 06:35 PM Thread Starter
milli629
I have a 95 wrangler 4.0L and I recently replaced the fuel filter and now it has a very low rpm (but it's been low for awhile) and it stalls sometimes when coming to a stop or when I push in the clutch while coasting. It will also stall if it idles long enough. I cleaned the IAC with no help. Could it be a bad fuel pump or possibly faulty spark plugs? Would appreciate some insight. Thanks
milli629 is offline
post #2 of 3 Old 06-28-2010, 07:15 PM
RubiconBlack
Possible bad regulator. Check the pressure at the rail while its idling. Hope this helps!
RubiconBlack is offline
post #3 of 3 Old 06-29-2010, 01:49 AM Thread Starter
milli629
I'll check it out. Thanks
milli629 is offline
stall , stalling
Engine stalls while idling GlennG Engines & Drivetrain 5 01-05-2012 09:40 AM
Electric Fan Cycyling On & Off When Vehicle Is Idling Rickster49426 Engines & Drivetrain 3 03-27-2010 09:28 PM
2.5 wrangler idles but stalls while driving!!! stat12985 Engines & Drivetrain 1 08-06-2009 01:31 PM
vibration when coasting/ slowing down rebelbill1972 Tires & Wheels 1 01-10-2009 11:12 PM
front shake when coasting Jeep-Ne-Time Tires & Wheels 3 10-17-2002 08:42 AM
