95 Jeep yj missing help! - JeepForum.com
post #1 of 2 Old 05-07-2014, 05:44 PM Thread Starter
Gervin
1980 CJ7
I have a 95 jeep yj 2.5 with a miss that I can't figure out! It only does it after it's warmed up and it's in closed loop. I've replaced a the 02 sensor and the Coolant temperature sensor and it still misses. It only happens under light throttle about 2000 rpms or a little above. It's not a steady miss but random maybe one cylinder then two or three untill you ease on the gas and it stops missing completely. I unplugged the vss and it ran great because it stays in open loop. Any help is appreciated!
Gervin is offline
post #2 of 2 Old 05-14-2014, 07:33 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The VSS crank and cam sensor all get their 8 volts from the same circuit. The VSS can begin to fail until it shorts internally. Once it does it will not start anymore. But it begin by giving little signs that get more constant over time until it does fail.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
