95 Jeep Grand Cherokee V8 5.2 liter - JeepForum.com
post #1 of 3 Old 03-03-2012, 06:52 PM Thread Starter
brokenmoonlit
Hi guys. I bought this jeep off of craiglists a month ago. First couple of days I had no problems and then they began to arise. My husband tells me that I should just junk it but I have fallen in love and I do not believe these are serious problems. Can you give me some imput as to what I should do. I have also done some research so I have some ideas..... Here it goes.......
1) I am having problems shifting. The car revs up between 2-3k before shifting, and it sounds like I am stomping on the gas, when I am not really doing that. I think that it is the speed sensor on the transmission? Any thoughts on this?
2) All of the sudden it overheats and the antifreeze pours out. I have to wait on it to cool down add more antifreeze in it and it will drive fine for a while, then it will do it again. I am thinking thermostat and maybe a flushing.
3) Coolant Level Low sign keeps coming on computer dashboard. I am thinking this is the coolant temperature sensor... I have already bought one just need to put it on......
4) It sounds like the lifters are chattering. I believe this is due to the problems on it from 1,2,3.????
Please share some thoughts with me on this? I only paid 1200 for the jeep, because the guy thought it was stuck in 4wd high he was just wrong lol.He just didnt know how to put it in 2wd. It took my brother to work on it...... for two minute and it was fixed. Any helpful info would be great I am in love and don't want to get rid of it.
Thanks so much,
Kelly
brokenmoonlit is offline
post #2 of 3 Old 03-04-2012, 01:59 PM
amtap97zj
First thing. Check the trans fluid for proper level and look at the fluid. If its brown instead of red , the transmission may be done. If the fluid looks ok you could try replacing the speed sensor. Transmissions are very particular. You should only use atf plus 4. Any other type is not acceptable and can cause erratic syptoms. The overheating could be a faulty thermostat that is sticking closed. Might also be a worn seal on the radiator cap. ( cheap fix). If these do not cure the problem the radiator will most likey need to be replaced. The chttering noise in the engine should only be happening when the engine is overheated. I only hope when you overheated the jeep you did not continue driving. If you didnt shut it down right away there could be major engine damage. After completeing any repairs i would disconnect the negative battery cable to reset the computer. Good luck
amtap97zj is offline
post #3 of 3 Old 03-05-2012, 02:57 PM
Foundrydude
If you've been overheating it enough to boil over the oil is ruined and will contribute to clattering. You may also be overheating the transmission fluid.
First things first, replace the thermostat or do whatever it takes to fix the overheating before you destroy the motor and transmission.
Once it runs at proper temperature you can change the oil and move on to troubleshooting the transmission.
Post over in the ZJ grand cherokee forum for better responses.
Good luck
Foundrydude is offline
coolant , lifters , overheat , speed sensor
Looking to buy Jeep Grand Cherokee txaggies08 Engines & Drivetrain 0 09-21-2011 01:22 PM
2001 jeep grand Cherokee j33pfr3ak Engines & Drivetrain 3 03-14-2011 07:27 PM
04 Jeep Grand Cherokee JeepGC121 Audio, CB & Ham Radios, GPS, & Electrical 0 07-09-2010 08:37 PM
01 jeep grand cherokee eckosho2k5 Engines & Drivetrain 1 12-25-2007 10:07 PM
Can a 2002 Grand Cherokee Radio fit a 1996 Grand Cherokee limited? banzayworld Audio, CB & Ham Radios, GPS, & Electrical 4 10-20-2002 11:25 PM
