95 G Cherokee major problems, help please? - JeepForum.com
post #1 of 3 Old 06-26-2012, 08:27 PM Thread Starter
rhettjeep
1995 XJ Cherokee
OK, so if you have clicked this thread hoping to help me out let me Thank you!
The problems I have been experiencing have just got worse over time, especially in this Texas heat. What will happen is whenever I am coming to a stop after driving for about 5 minutes, the cars idle RPM will drop significantly low ( about 250 ) and start to surge or pulse coming to a stop. When I am completely stopped the surge or pulse will continue but almost kill my Jeep. I will then push on the gas to rev up my RPM's some so that it does not continue. Then when I accelerate afterwards it will hesitate to get above 30 MPH.
That was at first the only thing happening. Then a week later when I accelerate past about 70+ the Jeep will surge again but not drop in RPM just go up and down as I accelerate.
Then just this past week, the car has almost completely died twice while driving. Sometimes it won't let me get past 30 MPH even if I floor the gas pedal. The weird thing about all this is that to make it go away for a little while all I have to do is pull over, turn off my car, then start it back up and it will drive fine.
I have no idea whats going on
Things replaced: TPS sensor, idle air motor, cap&rotor, spark plugs/wires.
rhettjeep is offline
post #2 of 3 Old 06-26-2012, 08:34 PM
jnicewan
Check for vacuum leaks, wiggle the vacuum lines while the engine is running to see if one might be cracked and not really leaking at times. I guess you dont have any codes? Do you have access to a scanner so you can monitor sensors like the MAP and HEGO (O2) sensors. Other than paying for guesses, were you having problems with the parts you already replaced. Do you have a way to test other parts like the MAP sensor, maybe even have a buddy you can borrow one from?
jnicewan is offline
post #3 of 3 Old 06-26-2012, 08:49 PM Thread Starter
rhettjeep
1995 XJ Cherokee
Thank you for replying, I have a guy at work that I can ask to borrow a scanner if he has one. Also though the check engine light comes on randomly every time this happens. When I replaced most of those things I was going off of what the AutoZone trouble shooting guide said. ( Going for cheap fixes ) lol
1995 , grand cherokee , hesitation , jeep , stalling
I am having major problems getting my jeep to crank. mstrowd Engines & Drivetrain 52 04-01-2012 09:35 PM
Major electrical problems :( Help junkamc Audio, CB & Ham Radios, GPS, & Electrical 1 10-31-2011 07:52 PM
Major electrical problems :( Hep! junkamc Engines & Drivetrain 0 10-31-2011 11:20 AM
Major Driveline Problems.. Myron37 Engines & Drivetrain 2 01-01-2011 03:51 PM
360 is having some major problems... HELP! scrible Engines & Drivetrain 1 01-30-2007 11:22 PM
