94 xj running hot - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 94 xj running hot
Advance Adapters SYE Kitsoconee offroad 10% off and free shipping offer and promo cHuge Soft top Sale
Unread 07-01-2012, 02:48 PM   #1
richardclarkjr
1994 XJ Cherokee
94 xj running hot
I have a 94 xj however this summer it seems to b running hotter then normal ive done everything possible to cool it down i even ripped out the t stat but on a hot day its running 230-235 it gets to the line right bfore the red any suggestions on what to do next
RichardclarkJr
richardclarkjr is offline   Reply With Quote
Unread 07-02-2012, 11:00 PM   #2
lauderdalechad
2006 WK
Is your fan working properly, have you tried a coolant flush, is there any leaks or antifreeze smells?
2000 jeep wrangler sport: 31" BFG ATS, auto - wrecked
1997 jeep grand cherokee: stock - gf's zj
2000 Silverado 5.3l Z71- sold
2006 Overland HEMI QDII
lauderdalechad is offline   Reply With Quote
Unread 07-02-2012, 11:05 PM   #3
dauster500
1987 YJ Wrangler
mud or dirt in the radiator if you wheel. put on a new radiator cap. for a 4.0 pretty sure its 16lbs, definitely do a coolant flush. check your hoses. when not moving the fan should be at full speed.
dauster500 is offline   Reply With Quote
Unread 07-03-2012, 08:59 PM   #4
richardclarkjr
1994 XJ Cherokee
Yes i do go mudding however i put in a 160 degree t stat n drained the radiator and i cleaned the over flow bottle wich had bout one inch thick brown substance in it i drained and filled the radiator with new clean antifrease back in it. The weather started getting hot again once again my engine temp started to rise i drained it again and this time i pulled out the t stat however when it gets to opperating temp the highest it gets is the white line right bfore the red starts..ive tried everything n its realy getting frusterating any advise would be great
RichardclarkJr
Unread 07-03-2012, 09:23 PM   #5
dauster500
1987 YJ Wrangler
Is it an automatic?
Unread 07-03-2012, 11:28 PM   #6
richardclarkjr
1994 XJ Cherokee
Yes it is n i installed a tranny cooler also
RichardclarkJr
Unread 07-03-2012, 11:36 PM   #7
9jeepcherokee5
I went through a mud puddle with my 95 grand Cherokee and went though the first time fine second time I did it stalled out on me and now I'm driving it on roads and when idles it makes this weird sound not metal hitting metal but as soon as you give it gas it goes away PLEASE HELP
9jeepcherokee5 is offline   Reply With Quote
Unread 07-04-2012, 12:53 AM   #8
lauderdalechad
2006 WK
Start a new thread and be way more specific then that
