94' 2.5L exhaust manifold gasket replacement - JeepForum.com
post #1 of 5 Old 10-04-2007, 09:04 AM Thread Starter
JayBanion
The exhaust manifold gasket is leaking. Would it be easier to remove the intake when doing the gasket seeing how it all tangled up with the header? And I would like to do a compression check on the motor. What should the compression be at on each cylinder. Around 160psi or so?
Thanks
Jay
2000 XJ Cherokee Sport auto, 2'' Rough Country BB, 31x10.5 Cooper STT's, soft 8's, flareless, chopped fronts, cut and folded rears
JayBanion is offline
post #2 of 5 Old 10-04-2007, 09:16 AM
frankiefire702
There is no exhaust manifold gasket. It's metal on metal. Check the torque on the bolts/studs and check for cracks in the manifold itself.
06 tj locked on 36's.
frankiefire702 is offline
post #3 of 5 Old 10-04-2007, 02:56 PM Thread Starter
JayBanion
haha are you sure that there is none. The gasket between the head of the motor and the exhaust manifold, because....i just bought one.
post #4 of 5 Old 10-09-2007, 07:13 AM
frankiefire702
I'm possitive... I'm alss possitive you didn't get the gasket at the dealer. They are available aftermarket though. Let me know if you find one when you pull the manifold off.
Maybe you could also point out the exhaust manifold gasket in this image.
post #5 of 5 Old 10-12-2007, 07:45 PM
SierraDave
I've replaced exhaust manifolds on an '85 and a '97 2.5L. Neither required a gasket.
SierraDave is offline
should I try to replace exhaust manifold gasket myself? brainfuct Engines & Drivetrain 4 10-10-2008 11:20 AM
Manifold gasket leak- how basd is this? 1speedlos Engines & Drivetrain 2 10-30-2007 10:30 AM
exhaust manifold gasket leak rainman0 Engines & Drivetrain 3 11-05-2006 06:45 PM
4.2L exhaust manifold installs without a gasket? Bobbywolf Engines & Drivetrain 3 12-07-2005 10:37 PM
No Exhaust Manifold gasket??? JazAddict Engines & Drivetrain 4 07-06-2004 11:07 PM
