93 jeep cherokee xj - JeepForum.com
post #1 of 5 Old 11-17-2012, 11:38 PM Thread Starter
Jayy
93 jeep cherokee xj
My clutch got really soft when I started it tonight. I got in reverse and got almost out of my apartment complex, when it got more loose and wouldn't let me switch gears at all. Had to leave it down the street. Don't know what the problem is any help would be appreciated thanks.
Jayy is offline
post #2 of 5 Old 11-17-2012, 11:43 PM
JLITTY
1946 CJ2A
Check the fluid in clutch slave.
JLITTY is online now
post #3 of 5 Old 11-17-2012, 11:49 PM Thread Starter
Jayy
Is that where I add the brake fluid?
Jayy is offline
post #4 of 5 Old 11-18-2012, 12:58 AM
jnicewan
Check the fluid in the clutch master cylinder. It is right beside the brake booster under the hood at the firewall, the cap is a small round cap you twist off. If the fluid is low you need to at least bleed the system but you probably have a leak somewhere. Look underneath at the trans, look under the master cyl and look under the dash where the clutch rod goes through the firewall to the master cyl for a fluid leak.
jnicewan is offline
post #5 of 5 Old 11-18-2012, 09:05 PM
JLITTY
1946 CJ2A
Yea.. Says clutch on it I believe
