93 GC has a ticking sound - JeepForum.com
post #1 of 3 Old 04-12-2004, 02:32 PM Thread Starter
demtjcj
well i know that this isnt good, but not sure if it is bad to the point of a new engine. i can hear a ticking noise when i am driving my car, higher rpms the faster it gets, then when i shut off my car it is still ticking. for a few minutes afterwards. is this a valve or piston making this noise and if so does it need a rebuild or can i replace the valves. any info would help. oh and it has 178000 miles on the original engine. thanks for the help
dan
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #2 of 3 Old 04-12-2004, 05:18 PM
Silver yj
If you shut your JEEP off and its still ticking then its nothing in the motor.I would start checking around under the hood if you can here it with the engine off to help pin point where the noise is.
Silver yj is offline
post #3 of 3 Old 04-12-2004, 06:03 PM Thread Starter
demtjcj
ill try that and see if i can see where it is coming from. thanks
dan
demtjcj is offline
Bad Idleing and Ticking Sound Mortifix Engines & Drivetrain 2 10-28-2008 05:40 PM
New '08 JK; weird engine ticking sound.. lordblack Engines & Drivetrain 0 07-28-2008 10:35 PM
Sound Bar/Sound Pods? Factory Radio Wattage? 05 TJ DJMunich Audio, CB & Ham Radios, GPS, & Electrical 7 01-03-2007 07:07 PM
My VDP problem adding sound bar and sound wedges jbggump Audio, CB & Ham Radios, GPS, & Electrical 3 11-09-2006 02:07 PM
Sound system for 2002 wrangler w/ premium sound Bryan_16 Audio, CB & Ham Radios, GPS, & Electrical 2 05-31-2002 09:17 PM
