92 YJ Broke driveshaft and yolk - JeepForum.com
post #1 of 10 Old 08-22-2013, 01:37 PM Thread Starter
ozell
Hello i just recently purchased a 92 YJ and I have a question. I just recently changed the u joints in the front and back, but while trail riding my rear driveshaft sheared right at the cv joint. When the shaft broke the yolk on my transfer case was damaged and now I'm looking at a moderate repair job. My question is this. Can something in the transfer case have caused the shaft to bind?
ozell is offline
post #2 of 10 Old 08-22-2013, 04:50 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Excessive driveline angle.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #3 of 10 Old 08-22-2013, 05:10 PM Thread Starter
ozell
Shouldn't the sye with the longer shaft eliminate that? It only has a 4 inch lift
ozell is offline
post #4 of 10 Old 08-22-2013, 05:39 PM
schitzangiggles
King of Macastan
Yes it should.
Crap I combined your thread with the other one...
Did/does your Tcase have enough fluid and is the drive chain broken?
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #5 of 10 Old 08-22-2013, 06:35 PM Thread Starter
ozell
Trans case seems fine other than the yolk being broke...no funny sounds or signs of a leak. I'm thinking some trash may have got into the u joint while installing but I really don't know.
ozell is offline
post #6 of 10 Old 08-22-2013, 06:36 PM Thread Starter
ozell
I haven't checked the fluid. I'll do that as soon as I'm back home...out of town at the moment
ozell is offline
post #7 of 10 Old 08-22-2013, 08:07 PM
Evildriver-3
Nothing in the t-case caused that, it's common to see when you exceed the angle. I have replaced many end yokes from going beyond the working angle they can be operated at without modification to the end yokes and the rest of the shaft.
You may just need to limit your rear axle
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #8 of 10 Old 08-23-2013, 07:47 AM Thread Starter
ozell
Any advice for repairing the yoke? It broke a large chunk out of the yoke on my t-case and I need to order a new one. I see lots of em online but I'm not real sure which one to get. Are they all basically the same or are some better than others?
ozell is offline
post #9 of 10 Old 08-23-2013, 01:30 PM
Evildriver-3
The end yoke you can get at your local driveline shop, no real better version, there are some different versions you could use and they have different lengths end to center V PP used to make a 4340 I'm not sure they are anymore. The yoke didn't break from power so I wouldn't worry about needing that 4340 piece, check it out and see if your into bind when you get it back together
]=Supershafts=[
post #10 of 10 Old 08-26-2013, 06:42 AM Thread Starter
ozell
Local driveline shop is helpin me match up the yoke. Hope to be back on the trails this weekend. Ty for the quick replies and best of luck to u guys
ozell is offline
