-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   92 YJ Broke driveshaft and yolk (http://www.jeepforum.com/forum/f19/92-yj-broke-driveshaft-yolk-1565725/)
ozell 08-22-2013 01:37 PM
Hello i just recently purchased a 92 YJ and I have a question. I just recently changed the u joints in the front and back, but while trail riding my rear driveshaft sheared right at the cv joint. When the shaft broke the yolk on my transfer case was damaged and now I'm looking at a moderate repair job. My question is this. Can something in the transfer case have caused the shaft to bind?
schitzangiggles 08-22-2013 04:50 PM
Excessive driveline angle.
ozell 08-22-2013 05:10 PM
Shouldn't the sye with the longer shaft eliminate that? It only has a 4 inch lift
schitzangiggles 08-22-2013 05:39 PM
Yes it should.
Crap I combined your thread with the other one...
Did/does your Tcase have enough fluid and is the drive chain broken?
ozell 08-22-2013 06:35 PM
Trans case seems fine other than the yolk being broke...no funny sounds or signs of a leak. I'm thinking some trash may have got into the u joint while installing but I really don't know.
ozell 08-22-2013 06:36 PM
I haven't checked the fluid. I'll do that as soon as I'm back home...out of town at the moment
Evildriver-3 08-22-2013 08:07 PM
Nothing in the t-case caused that, it's common to see when you exceed the angle. I have replaced many end yokes from going beyond the working angle they can be operated at without modification to the end yokes and the rest of the shaft.
You may just need to limit your rear axle
ozell 08-23-2013 07:47 AM
Any advice for repairing the yoke? It broke a large chunk out of the yoke on my t-case and I need to order a new one. I see lots of em online but I'm not real sure which one to get. Are they all basically the same or are some better than others?
Evildriver-3 08-23-2013 01:30 PM
The end yoke you can get at your local driveline shop, no real better version, there are some different versions you could use and they have different lengths end to center V PP used to make a 4340 I'm not sure they are anymore. The yoke didn't break from power so I wouldn't worry about needing that 4340 piece, check it out and see if your into bind when you get it back together
ozell 08-26-2013 06:42 AM
Local driveline shop is helpin me match up the yoke. Hope to be back on the trails this weekend. Ty for the quick replies and best of luck to u guys
The time now is 08:00 AM.
