91 Jeep cherokee problem Help! - Page 2 - JeepForum.com
post #16 of 24 Old 01-11-2014, 08:25 PM
rjbruzan
It sounds like a lifter is collapsing (due to being dirty) while hot at restart. Numerous oil changes with a high detergent oil may help it get. I have had good result with Rotella to clean up dirty engines. As others have said a Quality filter is manditory. Napa gold and Wix are good lower cost choices. Getting the engine to operating temp is important to cleaning it out. Dont be tempted to use an engine flush as this could be the death of the engine. I had one of the XJs get noisy for a period then quiet down. It now has 173000 on it and I run 95 miles a day with it. This is a common problem with the 4.0`s.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #17 of 24 Old 01-12-2014, 06:05 PM Thread Starter
91Cherokee7
1991 XJ Cherokee
If the engine was hot hours ago and if i let it sit until it was cold it sometimes ticks for a sec but if the engine was still hot the ticking would be non stop. Yet if it was anything major shouldn't the check engine come on?? But it does not so it must not be anything major
91Cherokee7 is offline
post #18 of 24 Old 01-12-2014, 06:13 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check Engine Light is for electrical malfunctions, not mechanical ones.
When you start it hot, and the tick is there, what happens if you shut the engine off and wait a few seconds and restart it? Tick gone?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #19 of 24 Old 01-12-2014, 08:30 PM Thread Starter
91Cherokee7
1991 XJ Cherokee
No..the tick/knock will still be there when engine is hot. The engine loses no power or jerks. Its just a loud noise.
post #20 of 24 Old 01-12-2014, 08:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Even if you shut it off and restart it immediately after starting it hot/ ?
post #21 of 24 Old 01-12-2014, 10:43 PM Thread Starter
91Cherokee7
1991 XJ Cherokee
YES...
post #22 of 24 Old 01-13-2014, 05:10 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's something I would try. Change JUST the filter to a Wix or Napa Gold.
post #23 of 24 Old 01-13-2014, 11:19 AM Thread Starter
91Cherokee7
1991 XJ Cherokee
Ok
post #24 of 24 Old 01-23-2014, 09:29 AM Thread Starter
91Cherokee7
1991 XJ Cherokee
Its been COLD 10 degrees for like the last week, I work the night shift and i sleep during the day but its been snowing and it just so happens on my days off so i may just wait till spring or if it warms up to like 40 degrees ill take my engine apart with some help to see why it ticks/knocks. Ill try to keep this up-to-date.
