91 Cherokee please help - JeepForum.com
post #1 of 4 Old 12-16-2011, 08:32 AM Thread Starter
krwilk11
I have a 91 jeep Cherokee and the rear end is shot. I need a Dana 35 3.07, I found a 94 wrangler rear axle Dana 35 3.07. Is this compatible? Also it needs new gears, which would you recommend?
krwilk11 is offline
post #2 of 4 Old 12-16-2011, 09:27 AM
oteps
1980 CJ5
If it needs new gears it probably isnt worth buying. Around here at the junk yards xjs are everywhere. You should be able to find a d35 that will be an exact fit for yours. Or you could find an 8.25 rear out of an xj with the same gears. They are a little stronger than a d35. I just took a d35 to the scrap yard this week because I couldnt sell it or give it away.
oteps is offline
post #3 of 4 Old 12-22-2011, 12:27 AM
tiny43
pretty bad when ya cant even give it away
tiny43 is offline
post #4 of 4 Old 12-22-2011, 07:22 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
And no one said the obvious yet....
One is SOA, one is SUA.
Just upgrade the turd before you waste more money on it. I can guarantee you could have a 8.8 under the rig for less coin that you will have in welding new perches etc and regearing that turdy5. Only difference is, one will break again, the other wont
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
2004 Grand Cherokee wheels on 1999 Cherokee Sport? jbroese Tires & Wheels 2 07-30-2010 10:15 PM
TJ owner looking for Cherokee/Grand Cherokee DD/slight offroader rubicon4x4 General Jeep & Off-Road Equipment 0 04-03-2008 01:26 AM
grand cherokee (wj) vs. cherokee xj fivespeedsteed General Jeep & Off-Road Equipment 1 07-28-2007 12:52 PM
cherokee vs grand cherokee which is better 4wheeling jocww General Jeep & Off-Road Equipment 9 01-15-2007 05:00 PM
Can a 2002 Grand Cherokee Radio fit a 1996 Grand Cherokee limited? banzayworld Audio, CB & Ham Radios, GPS, & Electrical 4 10-20-2002 10:25 PM
