90 Yj Wrangler Engine Problems - JeepForum.com
post #1 of 9 Old 07-17-2002, 10:24 AM Thread Starter
robb92
90 Yj Wrangler IGNITION AND ENGINE PROBLEMS
HI ALL, THE PROBLEM I'M HAVING WITH MY JEEP IS THAT WHEN THE JEEP GETS WARMED UP, I'M GETTING READY TO DRIVE DOWN THE ORAD IT STARTS TO SPUTTER AND THE THE ENGINE DIES, ITS A 2.5 LITER, I WAS THINKING IT MIGHT BE THE FUEL PUMP OR SOMETHING WITH THE IGNITION, CAN ANY OF YOU HELP ME PLEASE???
ROBB
robb92 is offline
post #2 of 9 Old 07-17-2002, 11:04 AM
Infedel
Fuel Filter
Try replacing the fuel filter(s).
Infedel is offline
post #3 of 9 Old 07-17-2002, 11:23 AM Thread Starter
robb92
I did that when I changed the oil, oil filter and spark plugs and wires. which was 2 months ago
robb92 is offline
post #4 of 9 Old 07-17-2002, 02:58 PM
BRAVO364
dies
does this seem to happen only after the vehicle is warmed up and does it crank right back up or just try to crank and die?
BRAVO364 is offline
post #5 of 9 Old 07-18-2002, 09:13 AM Thread Starter
robb92
it does die once it is warmed up, but you turn the key off and then back on to start it and it will take a couple of tries before it cranks over
robb92 is offline
post #6 of 9 Old 07-18-2002, 11:01 AM
BRAVO364
iT COULD BE THAT YOUR FUEL PUMP IS NOT ABLE TO HOLD PRESSURE.
BRAVO364 is offline
post #7 of 9 Old 07-18-2002, 04:37 PM Thread Starter
robb92
HOW DO I GO ABOUT CHECKING IT??? DO I HAVE TO TAKE IT TO A SHOP TO GET IT TESTED? BEING THAT I'M STATIONED IN ENGLAND IT WOULD BE HARD TO FIND A SHOP THAT DEALS WITH U.S. CARS, EXSPECIALLY JEEPS.
STUCK IN ENGLAND WITH OUT A GOOD AND CHEAP AUTO PART STORE!!!!
robb92 is offline
post #8 of 9 Old 07-19-2002, 07:58 AM
BRAVO364
Any local shop SHOULD be able to check your fuel pressure. Yours does have a carburator, correct? The reason I ask is that there is an ignition module near the water bottle that has been known to go bad. If this is the case the ignition model has 2 part numbers, 1 has superseded but is still available at some dealership, the part is the same for a 2.5 or 4.2L. p/n 4883922aa is 105.00 and p/n 53005079 is 96.00. it is an expensive part to just try out and I don't know the availability of it for you.
BRAVO364 is offline
post #9 of 9 Old 07-19-2002, 09:19 AM Thread Starter
robb92
THANKS I WILL TAKE IT TO A LOCAL SHOP, IT DOESN'T HAVE A CARB ITS FUEL INJECTED, WOULD THAT MAKE A DIFFERENCE?
robb92 is offline
Engine Problems brunhean Engines & Drivetrain 7 02-17-2010 08:00 AM
More problems w/ engine bay Rokjeep Engines & Drivetrain 1 02-11-2010 06:10 AM
wrangler ax-5 problems Rocker555 Engines & Drivetrain 0 02-10-2010 06:50 PM
engine problems! help! Dutchie123 Engines & Drivetrain 9 11-13-2008 08:15 PM
engine problems tippmann243 Engines & Drivetrain 11 04-02-2007 06:04 PM
