'90 YJ sputtering at speed - JeepForum.com
post #1 of 5 Old 06-20-2011, 09:07 PM Thread Starter
fchaleff
Ok, this is my first post... be gentle
I just bought a 1990 YJ 6 cylinder 4.2L. It hadn't been running for a while when I bought it... the PO said it was a month, but who knows? I just replaced the belts, cleaned the carburetor, seafoamed the engine and the gas tank, changed the oil and put on a new oil filter (in terms of anything that would have an effect upon the engine).
Driving tonight at speed (65 mph) in fifth gear, engine sounds like it's sputtering. I gave it some gas and the engine sputtered some more. No speed increase or increase in RPMs. I dropped it into fourth, same issue.
Then I took it onto the shoulder and let it coast, dropped it into third and gave her some gas, and the engine sounded normal--no sputtering--, the speed picked up (as did the RPMs) when I gave it some gas. I shifted up into fourth, got back on the road and everything was good. Up into fifth again... no problems for the rest of the drive. Fuel filter? At first I thought it was the clutch since the RPMs weren't going anywhere and it felt the same way as my old car did when the clutch died. But there wasn't any sputtering when that happened. Any ideas?
Last edited by fchaleff; 06-21-2011 at 10:07 PM. Reason: Back on a computer rather than a phone... easier to be more clear.
fchaleff is offline
post #2 of 5 Old 06-20-2011, 09:08 PM Thread Starter
fchaleff
Last edited by fchaleff; 06-21-2011 at 10:08 PM. Reason: I took out redundant info.
fchaleff is offline
post #3 of 5 Old 12-18-2012, 04:30 PM
lanny94
Any help
lanny94 is offline
post #4 of 5 Old 12-19-2012, 10:51 PM
jokerchief462
Plenty of things to conssider. The easy cheap stuff fuel filter, does it need a good tuneup look inside the cap at the contacts for each cylinder pull the plugs read the story of how it iis burning (pics attached), maybe the sputtering is from not running and you stirred up some debris in the tank and it clooged the filter sock in the tank.
Feul filter
Tune up (Rotor,cap wires, plugs)
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 5 Old 12-24-2012, 10:39 AM
90DesertTanYJ
Joker is prolly right here. Clogged filter will not feed enough fuel at high speed and a bad cap, wires or dirty plugs will do the same. Look for carbon tracing in and outside of the cap. Open the hood at night and see if there is a light show when you rev up the engine. ICM may also be at fault but check everything else first, its a $60 part.
90DesertTanYJ is offline
