Quantcast 89 YJ Cold Air Intake 2.5 TB - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 89 YJ Cold Air Intake 2.5 TB
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 02-18-2009, 07:51 PM   #1
darlingc
Hey guys im new to this jeep stuff. i put a homemade cold air intake on my islander a few days ago and it ran very well for a while then it started missing out as if it was having a hard time firing. so i decided to do a tune up on it. i changed the plugs wires rotor and dist cap. when i got the sparkplugs out i could tell that it was running very very rich. is there a sensor in the stock aribox or something that could have thrown my air to fuel ratio? so i put the stock air box on it and it runs fine now ... but slower.. is there anyway to get any more power out of those 2.5s because it doesnt like to go much faster than 60-65. Thanks Guys!
darlingc is offline   Reply With Quote
Old 02-20-2009, 08:47 AM   #2
darlingc
Bump bump..
Old 02-20-2009, 06:11 PM   #3
Cutlass327
1978 CJ5
Well, are there any vacuum lines or wires going to the air box? If so you need to find what they're for.
BTW, a 4cyl powered box isn't very aerodynamic, so speed isn't gonna be easy to get.
Cutlass327 is offline   Reply With Quote
Old 02-20-2009, 07:10 PM   #4
Unlimited04
Unlimited04's Avatar
what tires are you running? a Cold Air Intake is pretty much useless. see tech thread linked in my sig for that subject.
if you've got larger than stock tires you need to regear.
Unlimited04 is offline   Reply With Quote
Glock Forum
