89 4.0 (renix) controlled with a obd1 ecu. Help! - JeepForum.com
post #1 of 4 Old 01-19-2012, 07:01 PM Thread Starter
rafiki
I swamped my 95 GC. So I had to replace the engine. I grabbed a 89 Cherokee engine before I knew the engines were different. Right now the engine Mis fires and Rpms are bouncing around. I've swapped everything to the 89 engine. All electronics. Exhaust. And valve cover. I'm wondering if even tho this is a renix engine, with everything swapped over will my obd1 be able to control this engine ok? I have read there are differences in the head but I understood it was mostly air flow things. I still hVe the rad from the old engine and when it warms up I would be able to swap that on the new 89 engine. And help or advise would be great!
rafiki is offline
post #2 of 4 Old 01-19-2012, 10:48 PM
1986cj
What flexplate and dist did you use? guys swap the obd1 injection to 258s all the time so I dont know why you cant on a early 4.0
1986cj is offline
post #3 of 4 Old 01-20-2012, 12:47 AM Thread Starter
rafiki
The jeep has the 95 flex plate installed. I read somewhere that the exhaust manifold(95) won't line up the intake ports on that head(89). So maybe that is messing up my fuel spray from the injectors? Seems like dirty injectors but they are new. I think my solution is to swap the heads but I thought I would ask before I do. It won't be until the spring anyway. It's over -30 where I live in the winter and I do my work in the driveway.
rafiki is offline
post #4 of 4 Old 01-20-2012, 05:09 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
No need to swap the heads.
Radiator will be fine. I bet your distributor isn't indexed correctly.
cruiser54 is offline
4.0 , cherokee , engine , renix , swap
computer controlled for eddlebrock 2bbl ? yjrefurb Engines & Drivetrain 2 10-22-2010 01:06 PM
Pulse Width Modulation Controlled Blower Fan Gunnanmon Audio, CB & Ham Radios, GPS, & Electrical 2 10-07-2010 02:32 PM
4.0 HO cam to run with renix system =( NightRieder Engines & Drivetrain 0 01-13-2010 12:18 AM
Renix VS HO VS 4.2 q's DirtyCommanche Engines & Drivetrain 6 10-06-2005 06:42 PM
newbie ? What exactly is a Renix? ChaoticBastard Engines & Drivetrain 1 06-16-2005 10:45 PM
