**88 YJ Tranny leaking** - JeepForum.com
post #1 of 1 Old 12-15-2012, 07:25 PM Thread Starter
bigtom89
I have a 88 YJ with the 4.2 and 5 speed manual. I'm in the process of replacing the transfer case, when I removed the old one the tranny was dripping from the rear seal. I've never had a single drip in my driveway before. So I replaced what I thought was a bad seal and refilled the tranny, the tranny is still dripping. I didn't reinstall the transfer case yet cause I'm lost on this one. I started wondering if I install the TC does that act as the seal it needs?
I cleaned are where seal went, light coat of oil on the metal and a light coat on the seal then gently pressed then tapped it in. Cannot figure out why it is leaking.
Any help is greatly appreciated
1988 Wrangler YJ, 4"lift on 33" BFG Mud Terrians
bigtom89 is offline
231 input shaft , 4.2 , rear seal , transmission leak
