88 XJ Transmission Will Not Shift Itself - JeepForum.com
post #1 of 4 Old 11-17-2013, 02:06 PM Thread Starter
oldblackxj
1988 XJ Cherokee
My 88 XJ automatic trans (AW-4) will only shift if it is manually shifted. I have read that the majority will point to the TPS (throttle position sensor) as the most likely culprit. I have installed a new quality TPS and it did not provide me with the solution to the problem. I would like to get opinions from you with experience on where I should focus my efforts next. Thanks!!!
oldblackxj is offline
post #2 of 4 Old 11-18-2013, 01:25 AM
uberxj92
1992 XJ Cherokee
Transmission control module. Under glove box. Look for fuses for the transmission first.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 4 Old 11-19-2013, 02:22 PM
jokerchief462
If not the module you may need to drop the pan and change the filter. If the filter is blocked you will not generate the pressure required for it to shift.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 4 Old 11-19-2013, 05:03 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
FIRST place to look is at this fuse for the tCM.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
