87 wrangler with 258 spark problem. - JeepForum.com
post #1 of 4 Old 02-20-2003, 06:51 AM Thread Starter
Big Bill 33
My daughters 87 quit the other day and we cannot get it cranked. Upon futher checking I am not getting a spark from any off the plug wires. I have voltage at the connector on the distributor where it hooks to the wiring harness. Also when I turn the engine over I have voltage at the end of the wire fron the coil to the dist, but no voltage out the dist wires to the plugs. Any suggestions as to what to check. Also there is a steady voltage of about 13 volts to both sides of the coil, I know on my cj that one side has less voltage than the other, could this be a problem. All replies are greatly appreciated. Thanks for the post.
Bill Green
Big Bill 33 is offline
post #2 of 4 Old 02-24-2003, 08:10 PM
critters
no spark
hi,this is from the factory shop manual
possible causes
bad cap or rotor
bad control module or bad ground
short in coil
defective ecu (computer)
i had the same problem in my 89 and it was the computer.
hope this helps. critterbill
critter bill
critters is offline
post #3 of 4 Old 02-24-2003, 10:32 PM
CSP
You should have the same voltage on both sides of the coil when cranking. It will go down on one side once the key is in the run position. Sounds like either a bad ignition module or a bad pickup coil in the distributor.
Is this a 258 or a four cyl?
CSP is offline
post #4 of 4 Old 02-25-2003, 06:42 AM Thread Starter
Big Bill 33
Thanks for the help folks. It was the 16 dollar ignition module. It runs great now and even gets better gas mileage.
Bill Green
'06 Wrangler Radio Problem MTDennis Audio, CB & Ham Radios, GPS, & Electrical 3 01-25-2011 02:40 PM
very strange 4.2 spark problem geridr Engines & Drivetrain 1 06-08-2009 05:43 PM
2002 wrangler ecm problem jeepin_1963 Audio, CB & Ham Radios, GPS, & Electrical 0 05-13-2009 03:07 PM
97 Wrangler Cassette Player problem KilroyJC Audio, CB & Ham Radios, GPS, & Electrical 15 08-10-2005 08:10 AM
Ignition problem 2,5 : low or no spark Heikotomfelde Engines & Drivetrain 2 06-22-2004 02:42 AM
