82 Dana 30 front info ASAP - JeepForum.com
post #1 of 2 Old 04-21-2013, 08:46 PM Thread Starter
RoughIdle
1982 CJ8
Hey there, the front end in my 82 cj8 is starting to get some grinding going on and i know it is the inner bearings, the ring and pinion is fine i just had the cover off. I would like to do this myself i do not want to take it to the shop, the only problem i can see with this job is shimming. I am just replacing the bearings so do i have to re-shim and if i do is difficult to get it correct.
Right now i am on Morris4x4center.com looking at a master kit and it is only showing one seal and and it does not exactly tell me which bearings i am getting, what should i need for bearings seals and shims.
If anyone could help me out i would really appreciate it thanks
RoughIdle is offline
post #2 of 2 Old 04-22-2013, 07:37 AM
Evildriver-3
If you only need the pinion bearings why don't you visit your local mom and pop parts store and get them right there and be done with it and help your local area.
You can use your local (non chain china parts ***** house) parts store
You can visit your local driveline shop also.
Then you don't have to buy the other bearings or worry if it's right or wrong as you'll see it right there
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
