8 help - JeepForum.com
post #1 of 3 Old 04-06-2012, 07:12 PM Thread Starter
USAXJ
8 help
My rear diff started whining after being stuck in the mud for about an hour. I got it home and swapped the fluid but found no water. The fluid was very runny and dark which I thought was odd since it was only about a month old. I swapped the fluid with 75-90 and the whine didn't go away. I just learned that the LSD requires 75-140 and I'll be doing that first thing in the morning. My question is:if does the whine indicate that it's too late and the clutches are worn? I'm a differential noob and any input would be greatly appreciated.
USAXJ is offline
post #2 of 3 Old 04-07-2012, 09:21 AM
Technohead
Whining probably indicates bearings. Time to rebuild or replace.
-Eric
Technohead is offline
post #3 of 3 Old 04-07-2012, 11:22 AM Thread Starter
USAXJ
I just pulled the cover and had to scoop a bunch of sand out. The magnet was also fouled out with shavings so now I'm tearing into it replacing more than I wanted to.
USAXJ is offline
