8.8 TJ Brackets - JeepForum.com
post #1 of 8 Old 03-13-2007, 08:27 PM Thread Starter
slowTJ88
8.8 TJ Brackets
I'm starting to build up an 8.8 for my TJ and I haven't decided which brackets to use. What are you guys using, how do you like them, where did you get them from, and how much did they cost?
Thanks
1985 CJ7 Laredo
258, T176, D300
31x10.50s
slowTJ88 is offline
post #2 of 8 Old 03-13-2007, 09:01 PM
JSBlu974X4
there are many types..MORE from Mountainoffroad.com or teraflex (which I went with and VERY LITTLE grinding) from DC4wd just for starts...
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #3 of 8 Old 03-13-2007, 09:06 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Here's a few more options:
Rusty's - made for the 3.25" 8.8 axle tubes
Rubicon Express (requires grinding)
Mad4wd
Clayton's
Currie
Carolina Rock Shop
My brackets are home built. A friend bought brackets from Mad4wd and they are nice. I would imagine they are all pretty comparable as long as they are made from 3/16".
Wheelin98TJ is offline
post #4 of 8 Old 03-13-2007, 09:17 PM
MQ79
I used MORE brackets on mine. They were very good quality and fit very well. Plus you can buy each bracket seperately if you need to. That way you don't end up with brackets you don't need if you go with a 3 link rear, or want to go with Nth degree shock shifters, or something else.
MQ79 is offline
post #5 of 8 Old 03-14-2007, 12:15 PM
GSW
Carolina Rock Shop set mine up. Brackets are beef. No problems.
92 YJ
GSW is offline
post #6 of 8 Old 03-14-2007, 04:50 PM Thread Starter
slowTJ88
Thanks guys. How much did the CRS brackets cost you?
1985 CJ7 Laredo
258, T176, D300
31x10.50s
slowTJ88 is offline
post #7 of 8 Old 03-15-2007, 09:59 PM
smurison14
anyone considering the ballistic fab units ( bottom coil spring mounts) i mean theyre like 20 bucks
smurison14 is offline
post #8 of 8 Old 03-21-2007, 08:09 PM
yellow04
As of now, CRS doesn't have the brackets.
yellow04 is offline
TJ Tweeter Brackets? gov-t_mule Audio, CB & Ham Radios, GPS, & Electrical 27 09-27-2013 12:19 PM
8.8 ZJ Brackets redhatman Fabrication Shop 2 12-19-2008 10:09 PM
Speaker Brackets JeeperAbe Audio, CB & Ham Radios, GPS, & Electrical 10 01-30-2008 09:13 AM
Big Boy seat brackets TJ Clay General Jeep & Off-Road Equipment 6 01-25-2008 11:24 PM
recovery tow kit brackets DYOLLNAVE Fabrication Shop 4 11-13-2007 09:27 AM
