78cj 400auto fluid is pink - JeepForum.com
post #1 of 9 Old 03-15-2014, 04:50 PM Thread Starter
stillmuddin82
Ea I changed my transfer case today and the fluid that came out of the tranny tail shaft was pink. Not red. Almost like strawberry milk. Is that normal?? Could it have had some kind of stop leak in it or what?? What should I do??
stillmuddin82 is offline
post #2 of 9 Old 03-16-2014, 09:46 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I assume your running a Q trac. The recommended oil for that case should be the same color as gear oil. If it has a part time case in it, then it may be running ATF instead.
jeepdaddy2000 is offline
post #3 of 9 Old 03-16-2014, 09:49 AM
streetglideok
2005 KJ Liberty
Pink is either very frothy with foam/air or sign of water intrusion. What t-case is it?
streetglideok is offline
post #4 of 9 Old 03-16-2014, 10:11 AM Thread Starter
stillmuddin82
It's the older q trac full time. I put tcl1 fluid in it just for the q trac. It's the tranny fluid that's pink.
post #5 of 9 Old 03-16-2014, 09:37 PM
jeepdaddy2000
1971 CJ5
Wow did I misread this....
post #6 of 9 Old 03-17-2014, 08:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
When in doubt, change it.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #7 of 9 Old 03-18-2014, 08:12 AM
jon1371usmc
I'm with streetglideok in thinking the transmission was overfilled causing it to become frothy with air bubbles. Either way, I would do a full flush immediately.
jon1371usmc is offline
post #8 of 9 Old 03-18-2014, 06:15 PM
carnuck
1984 J-Series Truck
If you check the dipstick and it's not the same color, you may have had seepage stuck between tcase and trans that got water in from the top. If it is pink then the trans cooler may have imploded. If so, the rad will be low often and a pinkish color too. Just happened on my near new 3 core in my Comanche that I can't find the receipt for to warranty it out. AW4 has been running 1/2 ATF and 1/2 antifreeze since I've been too sick to work on it. I have another trans to go in but not healthy enough to work outside (or go to my new job even)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #9 of 9 Old 03-19-2014, 01:16 PM Thread Starter
stillmuddin82
Thanks everyone. Really needed the advice
