72 CJ5 running fine one day, won't start the next - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 72 CJ5 running fine one day, won't start the next
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-01-2012, 06:35 PM   #1
redtampa
1972 CJ5
All, I need some advice. I purchased this CJ5 in May and have been driving in frequently since. The engine is an AMC 304.
I drove it the previous weekend but when my wife tried to drive it during the week she could not get it to start.
The Jeep will crank freely and quickly but will not fire.
I have replaced the coil and tested spark (pulled #1 plug inserted screwdriver, spark jumped to engine block).
I pulled the fuel line from the carb and turned her over, fuel spurted into the jar I held.
So I have spark, I have fuel, I have engine crank speed. I feel like timing check is next but I am on unfamiliar ground. How can I check/set the initial timing? I am uncertain what type of dizzy but here are some pics:
Other posts have mentioned timing chain jumps, any tips on how to check this?
Thank you guys in advance for any guidance you can provide. I love my CJ and can't stand to see him sitting there
redtampa is offline   Reply With Quote Quick reply to this message
Unread 12-01-2012, 08:44 PM   #2
redtampa
1972 CJ5
Oops, posting the pics that way did not work.
Let me try this:
http://i212.photobucket.com/albums/c...10125954PM.jpg
http://i212.photobucket.com/albums/c...10125937PM.jpg
http://i212.photobucket.com/albums/c...10125911PM.jpg
Unread 12-01-2012, 08:58 PM   #3
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Look for a ceramic part that either has wires on each end of it or one that plugs into a socket. It is called a ballast resistor. It may look like this one in this link:
http://www.partsgeek.com/gbproducts/...FdKd4Aod4U0AlQ
Jump it with a wire and see if it starts. If it does start, replace it.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline   Reply With Quote Quick reply to this message
