71 CJ rear axle into 99 TJ - JeepForum.com
post #1 of 3 Old 09-05-2012, 12:55 PM Thread Starter
pdx99TJ
You guys are going to have to bear with me here my mechanical and technical skills and knowledge are currently in the "development" stage. I have researched the topic slightly but am having issues finding the right specifications.
I have access to a fully built rear dana 60 that was going to get mounted on a 71 cj at a very good price and would love to jump on the opprotunity, but i am unsure if the axle will work under the TJ. The 71 CJs rear axle had the differential offset towards the passenger side. I am unsure how much the offset is. I hear that ford 8.8s are offset as well (around 1.5 -2 inches). My question is does anyone know what the offset distance is on 71 cj rear axle? and if so will the offset distance put too much stress on my driveshaft?
I also know that the d60 didnt come out of the CJ. i can get the numbers off the actual axle this weekend. i think its from an old ford though.
I have a 99 tj with 3.5 inch lift and a SYE
pdx99TJ is offline
post #2 of 3 Old 09-10-2012, 09:38 AM Thread Starter
pdx99TJ
bump, cmon anyone?
pdx99TJ is offline
post #3 of 3 Old 09-11-2012, 07:18 PM
BlueRubiconrich
I had a 71 CJ5 so haer we go.
1The 71 Dana 44 in a CJ5 is offset and narrow track you can not use it.
2the 80's CJ wide track axles are still not wide enough for your TJ.
3 A Scout 2 rear Dana 44 is wider then a CJ not not as wide as a TJ
4 You could use a Ford 8.8 or a Isuzo Dana 44 close. see JP mag
5 or a TJ/TJL rear Dana 44 or TJ/TJL Rubicon Dana 44
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
Your axle end swaybar relocation for OTK Hussler Advanced Jeep Tech 17 03-29-2014 08:58 PM
TJ front axle stretch Echoman Advanced Jeep Tech 9 05-28-2012 10:06 AM
Axle Builds and Swaps JLC08JK Advanced Jeep Tech 9 12-27-2011 08:37 PM
