62mm throttle bodys - JeepForum.com
post #1 of 6 Old 10-02-2012, 10:21 AM Thread Starter
Moparfreud
62mm throttle bodys
Just purchased a 62mm throttle body from jeepersandcreepers.com and was wondering if anyone else has had any experience with them??? 179 us dollars shipped. The guy was very polite and did let me know the throttle body spacer was a waste of money.... My jeep is a wrangler 4.0 5 speed 1997
Moparfreud is offline
post #2 of 6 Old 10-02-2012, 10:39 AM
mdm
Farm Wheeler
Let's see if I follow this correctly. You bought the throttle body after the seller told you it was a waste of money?
He was correct. It is a waste of money for a stock 4.0L engine.
Kudos to the guy at jeepersandcreepers for his honesty.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 6 Old 10-05-2012, 10:44 AM
srmitchell
He said the throttle body spacer was a waste of money, not the throttle body.
I work on Mopars
srmitchell is offline
post #4 of 6 Old 10-05-2012, 10:53 AM
mdm
Farm Wheeler
You're right. I guess I need to revise my previous comment.
50% kudos to the guy at jeepersandcreepers for his honesty. He should have told the OP that the throttle body is also a waste of money on a stock 4.0L.
mdm is offline
post #5 of 6 Old 10-05-2012, 12:09 PM
Always2L8
1982 CJ8
Unless you increase the air flow through the intake and exhaust, the large bore throttle body probably won't be too beneficial. This would include larger volume air intake, and better flowing exhaust (i.e. Borla/Banks header, hi-flow cat/muffler, larger exhaust pipe). This is a lot money per pony (hp) gained. You may feel a little better throttle response? Also, not too sure how a mopar OBDII puter handles such changes. Perhaps someone on here has experience with it. The large bore TB with a cold air intake does sound a bit cooler when you go WOT. That is if it doesn't whistle on you.
The only benefit of the throttle body spacer, for me anyway, was better clearance/access to TB sensors and better alignment with the throttle and tranny "kick down" cables. But my set up is pretty far away from stock. Otherwise, as per above, a waste of money.
Not trying to be a Debbie Downer. It may help in the higher rpm ranges.
Good Luck
Always2L8 is offline
post #6 of 6 Old 10-06-2012, 06:29 AM
Always2L8
1982 CJ8
Just in case you haven't seen this. Check this link http://www.jeep4.0performance.4mg.com/intake.html
Does a 62mm throttle body really make a difference? firejeep48 Engines & Drivetrain 29 03-25-2011 04:15 AM
62mm throttle body advice alexRubicon2003 Engines & Drivetrain 1 10-02-2007 10:51 PM
Edge 62mm TB classicxj96 Street Jeep Forum 7 07-07-2007 11:19 AM
62mm TB.... Boring Q's Jmila1901 Street Jeep Forum 12 12-02-2006 10:00 AM
62mm throttle body spacer 3pac6pac Engines & Drivetrain 3 10-02-2006 07:15 PM
