6 lug 8.8? - JeepForum.com
post #1 of 8 Old 10-16-2007, 12:20 PM Thread Starter
red87yj
red87yj's Avatar
1987 YJ Wrangler
6 lug 8.8?
i did the search but didnt come up with anything. can the ford 8.8, as it comes out of an explorer (disks and length) be adapted to a 6x5.5 lug patern to match a dana 44 front out of a waggy? i found a lugadapter online for 5x4.5 (now) to a 6x5.5, but it seems that this is a little thick at 2" per side and over 200 shipped for both sides (sold seperatly) anyone run into anything like this before? or should i just go pull the other d44 out of the wagoneer that i got the front out of?
thanks all
zach
1993 YJ with a 4.0 & TF 999 & Np 231 (All to change soon!)
SOLD!!!87 Red YJ with 95 4.0 & NV 3550 & Dana 300 Flipped
3.5 BDS Lift
red87yj is offline
post #2 of 8 Old 10-16-2007, 12:34 PM
ajmorell
ajmorell's Avatar
I believe the ford full size trucks are 6 bolt (not sure of pattern) and they are 8.8s, but they might be too wide for your application.
ajmorell is offline
post #3 of 8 Old 10-16-2007, 05:03 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Full size 8.8s are 5 lug.
You could probably get custom shafts from Moser in any bolt pattern for an Explorer 8.8.
Superior may even be able to help you since they are now making the Super 88 kit. They normally drill the axle shafts for both 5 on 4.5 and 5 on 5.5 pattern but maybe they could do a set for you with the 6 on 5.5 pattern.
Have you considered running 5 on 5.5 up front?
Have you looked on ebay for cheaper bolt pattern adapters?
Wheelin98TJ is offline
post #4 of 8 Old 10-16-2007, 09:58 PM Thread Starter
red87yj
red87yj's Avatar
1987 YJ Wrangler
i have access to some 6 lug rims so i want to stay there if i can. i think im resorting my self to carrying 2 spares. my bro has a 'manche so there will be plenty of room to throw some spares in there.
if i did get custom shafts made, how would i set up the disk brakes?
the other thing that i was thinking is that i go pick up the rear 44 from the waggy that i pulled the front from, but i like having the stronger 8.8 and the rear disks.
thanks all
later
Zach
3.5 BDS Lift
red87yj is offline
post #5 of 8 Old 10-16-2007, 10:47 PM
ajmorell
ajmorell's Avatar
thanks all
later
Zach
The shafts won't affect how the brakes are setup...the bracketry is still the same...you will just need to find rotors with that bolt pattern that are the right diameter.
ajmorell is offline
post #6 of 8 Old 10-22-2007, 12:32 PM
Alcatraz
You could have the front or rear flanges and brake rotors index drilled and install new wheel studs.
'04 Wrangler X, 4.0L, auto, 3.73s. 31x10.50 Sport Kings, stock suspension.
Alcatraz is offline
post #7 of 8 Old 10-22-2007, 08:49 PM
JTB51B
Talk to a machine shop. This is NOT a really tough thing to do. Just make sure you have enough flange to do it. I would imagine 2 hours or so to re-cut the flanges. You can re-drill the rotors yourself after you have the flanges cut.
Jason
DD-- 2005 Dodge Ram 2500 Cummins TD Quad Cab 4x4 6 speed
Toys:
1998 Sport Auto trans, 3.73 gears, D30/lockright D44/Detroit, 33" Mud tires, FT LCA's JKS Adj. Trac bar FT 4" coils, RE GEN II Disco's--1 1/4 JKS BL, 1" MML XD9000i up front, HD bumpers with extraction points.-Done.
1973 cz 250 MX Not much suspension, but 36 BHP at 6k rpms!
2006 Rhino SE, 27" Mud lites and a cupholder.
JTB51B is offline
post #8 of 8 Old 10-22-2007, 09:51 PM
jp360cj
1977 CJ7
I'm not sure if it's an 8.8 or not, or what the interchangeability might be, but the late 90s (97 & up) F-250 light duty, which has the same body style as the F-150, instead of the big body like the Super Duties...but i think they had 6 lug, not sure of the exact pattern and couldn't find it anywhere. i do know it was an odd pattern at the time, but it might be worth checking out.
jp360cj is offline
