5.2l squealing HELP! - JeepForum.com
post #1 of 6 Old 05-19-2013, 02:22 PM Thread Starter
grandcherokee94
I have a 98 ZJ with the 5.2L,I have replaced the idler pulley,a/c clutch and pulley,tensioner pulley,power steering pulley,and a new belt.I haven't drove the jeep in over a month now because the squeal will not stop,you don't hear it at idle,but gets loud as hell when I give it alittle bit of gas. I do not know what else to do and because of the squeal I have put a stop on the build. I don't know if there anyway to tighten the belt,before replacing everything I did WD-40 and also dish soap,which would stop it for about an hour before it came back,Please help me!
1994 ZJ-4.0L HO,K&N CAI,TB spacer,Flowmaster Duel Exhaust,8000k HID,White Face Gauges,Pillar Gauges,3.5 Tuff Country lift,Much much more!-SOLD!
1998 ZJ Limited-5.2L AWD
Build Tread:
1996 ZJ Limited-5.2L AWD
grandcherokee94 is offline
post #2 of 6 Old 05-20-2013, 07:14 PM Thread Starter
grandcherokee94
Can anyone help me out?!
Build Tread:
post #3 of 6 Old 05-21-2013, 12:38 PM
Pierre_r
1989 XJ Cherokee
Waterpump or alternator both those will squeal before they die.
Pierre_r is online now
post #4 of 6 Old 05-22-2013, 08:25 PM Thread Starter
grandcherokee94
Thanks,I'll have to check into those.
Build Tread:
post #5 of 6 Old 05-23-2013, 07:03 AM
tp72chev
1997 WJ
You stated that you replaced the tensioner pulley but not the whole tensioner. If you spray the belt with water or anything and the noise goes away then you problem is the belt or the tension of the belt. Since you sprayed the belt with wd40 you need to replace it as well as clean all your pulleys. If there is rust on the crank pulley wire brush it and clean it. I would also replace the whole tensioner.
tp72chev is offline
post #6 of 6 Old 05-23-2013, 11:20 AM Thread Starter
grandcherokee94
I was planning on replacing the whole tensioner soon,but since it's almost $70 I didn't want to get that just in case that didnt work either,so was wondering if theres anything else that could be causing it,just getting tired of dumping money into it and the noise not going away
Build Tread:
