5.2 won't start - JeepForum.com
post #1 of 3 Old 09-11-2013, 03:06 PM Thread Starter
tapalmer99
1995 XJ Cherokee
5.2 won't start
I have a 1995 Grand Cherokee with 160k.
I got home and turned off engine, 30 minutes later it wouldn't start. It just turns over but won't fire.
I get a spark when I put a wire near ground. I shot starting fluid down the throttle body, but didn't catch even once (I ruled out fuel pump due to that).
I was looking to replace the timing chain, as I thought it had jumped a tooth, but a mechanic said that was unlikely.
I am thinking Crank Position Sensor, or Cam Position Sensor - but didn't get any engine light warnings. Since I disconnected the battery to do work, I was told that any codes would have been lost.
Any help is appreciated. This is my primary vehicle.
Thank you!
tapalmer99 is offline
post #2 of 3 Old 09-11-2013, 11:57 PM
uberxj92
1992 XJ Cherokee
Those sensors sound likely. If jumped time it wouldn't crank smooth. Check coil wires and plug wires
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 3 Old 09-12-2013, 01:24 PM Thread Starter
tapalmer99
1995 XJ Cherokee
Thanks. I was told to check the plugs for fouling, harness for shorts, and MassAirFlow by removing plug.
I have been going through 1.5-2.0 quarts of oil each 1,000-1,200 miles and mileage is down to 7.5-8.0 around town (12-14 on hwy, used to be 20-22!).
5.2 , sensor , spark , start
