5.2 318 proformance - JeepForum.com
post #1 of 12 Old 10-28-2012, 03:51 PM Thread Starter
Pitbull330
5.2 318 proformance
Alright guys, I have a 97 Jeep Grand Cherokee Larado. With A 5.2. and I am Looking for more Horse Power. I have An K&N Cold Air Intake. Jet Performance Super Chip. 26lb Accel injectors. Accel plugs and wires cap and rotor. I guess im asking if there are different heads, cams i can install myself. What kind and where i can get them. if u guys could help post pictures. point me in the right direction that would help. Thanks Pitbull330
Pitbull330 is offline
post #2 of 12 Old 10-28-2012, 04:00 PM
Trombly
Besides as total engine overhaul, sounds like all you can do is exhaust/weight reduction. Make sure your injectors match the amount of air flow your putting through the engine or else you'll just be wasting fuel/getting less performance.
Trombly is offline
post #3 of 12 Old 10-28-2012, 05:00 PM Thread Starter
Pitbull330
Forgot already did the exhaust. NASCAR style comes out before the rear tire. I want to do an overhaul. Injectors match with the air flow also. I am an auto technician by trade. Just don't know much about engine performance.
post #4 of 12 Old 10-28-2012, 05:25 PM
Trombly
Alright cool well at least you'll be knowing how to do everything, I'm not a 5.2 guy so someone else will hopefully chime in
Trombly is offline
post #5 of 12 Old 10-28-2012, 05:33 PM Thread Starter
Pitbull330
I wonder of anyone knows if I can swap out my heads with the 5.2 magnum heads. Would I need a new timing chain and gears. Or is that only when I replace the camshaft.
post #6 of 12 Old 10-28-2012, 05:40 PM Thread Starter
Pitbull330
post #7 of 12 Old 10-31-2012, 05:14 PM Thread Starter
Pitbull330
I guess I need a Mopar Performance forum
post #8 of 12 Old 10-31-2012, 06:33 PM
Trombly
Ya probably sorry dude
Trombly is offline
post #9 of 12 Old 11-01-2012, 05:43 AM
DimebagDave
When I had my 88 ramcharger, it had the 318. One of my favorite engines. I blew the heads somehow and my father got me some 360 heads for cheap. It gave me a bit more low end growl and more balls at low rpm... With that said, gas mileage was crap and higher rpm were non existent.
1999 Jeep Wrangler Sport Unlimited X 4X4 - S6 181HP 4.0L, Red Body Black Trim, Tan Hard and Soft Top, and 32RH Tranny(?)
DimebagDave is offline
post #10 of 12 Old 11-01-2012, 11:06 AM
Bama_WJ
Check out this guys build. Might give you some ideas...
http://www.jeepforum.com/forum/f22/m...build-1412306/
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #11 of 12 Old 11-01-2012, 02:08 PM Thread Starter
Pitbull330
Thanks man.
post #12 of 12 Old 11-03-2012, 12:18 AM Thread Starter
Pitbull330
Thanks
