5.0 vibration damper - JeepForum.com
post #1 of 2 Old 08-22-2005, 10:56 AM Thread Starter
rustyCJ
i noticed today that the rubber that lives between the weight ring(?) and body has started to slide out. can i just use a jaw puller and pull the ring off, reseat the rubber, and press the ring back on?
i dont know if the ring has started to spin, if its loose or anything right now but i really dont like the way it looks. are the weight rings set on in corralation with the crank in some regards? is there some way i can check to make sure it hasnt shifted or seperated?
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #2 of 2 Old 08-22-2005, 11:45 AM
gosupes
Some dampers are injection molded, not pressed together. I would hesitate to pull one apart and try and reseat anything. Visit http://www.damperdoctor.com/ - I bought a rebuilt unit from them last year for about $60, looked like brand new and quick turn around time.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
Cant find 2.5L damper W/O serpentine? blazer3664 Engines & Drivetrain 0 02-28-2009 02:47 AM
Steering Damper (cheap vs. expensive) Norolas Tires & Wheels 5 02-12-2009 12:42 PM
4.2 Vibration Damper Pulley Noise? mudlab Engines & Drivetrain 0 01-15-2008 08:32 PM
Steering Damper Replacement Paveway3 Tires & Wheels 7 12-05-2007 05:47 AM
Replacing steering damper/stabilizer Abanks Tires & Wheels 6 08-25-2002 07:37 AM
