4wd vacuum hose - JeepForum.com
post #1 of 3 Old 12-31-2012, 12:57 PM Thread Starter
VanessaW62
4wd vacuum hose
Lost my 4wd and thinking has to do with hose to port? Can't find a diagram for assistance for my 1990 Wrangler.
VanessaW62 is offline
post #2 of 3 Old 01-01-2013, 11:40 PM
seattle_yj
Are you talking about the vac actuator? It's located on the passenger side and goes up the block and connects to a vac line by the passenger side firewall. If you want you can lock the actuator manually. Search the forum for '4wd actuator override' and you will find a ton of articles about how to do it.
seattle_yj is offline
post #3 of 3 Old 01-02-2013, 08:38 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's a link. For an XJ but it's essentially the same setup.
http://www.cherokeeforum.com/f51/fre...ss-91-a-38629/
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
