4wd problems - JeepForum.com
post #1 of 3 Old 09-07-2013, 11:49 AM Thread Starter
olewilly
1989 MJ Comanche
4wd problems
I have an 89 jeep comanche. When I go to put it in 4wd it is very hard to get it to go in. When it goes in it works perfectly fine. And I have a really hard time getting it out of 4wd too. Sometimes I think it's just not going to. I want to start trail riding more and I really want this fixed. Please help
olewilly is offline
post #2 of 3 Old 09-07-2013, 09:25 PM
uberxj92
1992 XJ Cherokee
Check the linkage make sure it isn't bent. Check the fluid in the Tcase.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 3 Old 09-07-2013, 09:33 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's how the factory suggests you shift the transfer case and I've been doing this since these things were new and I worked at the dealership. Quoted from the owner's manual.
"To engage, shift the transfer case lever from 2H to 4H while the vehicle is moving at any legal speed". I let off the gas, throw the lever, and then tap the gas and let off.
4L position: " To engage, slow the vehicle to 2-3 MPH , shift the transmission to Neutral, then shift the transfer lever to the right and pull firmly rearward to 4L".
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
