4wd low - JeepForum.com
post #1 of 5 Old 04-20-2012, 08:50 AM Thread Starter
spelow23
4wd low
So I put a zone 4" suspension lift kit in. The kit had a 2" transfercase drop and a relocate bracket for the 4wd linkage. I can't seen to get it in to 4wd low. Any solutions or answers on the problem?
spelow23 is offline
post #2 of 5 Old 04-21-2012, 06:31 AM
vic_sinclair
The linkage has to spot-on for it to go into 4 low. You can try to adjust it until it works or you can buy a Novak cable shifter.
vic_sinclair is offline
post #3 of 5 Old 04-30-2012, 05:05 PM Thread Starter
spelow23
What web site is the best place to find that
spelow23 is offline
post #4 of 5 Old 04-30-2012, 05:25 PM
biffgnar
biffgnar's Avatar
JF is a pretty good spot. Just use the search function. This question asked many times and there are threads where pictures and diagrams posted that show the trunion nut for adjusting.
Romney in 2020!
biffgnar is offline
post #5 of 5 Old 04-30-2012, 05:32 PM
Technohead
You could also get an SYE and double-cardan driveshaft. Whats the point of lifting if you turn around and lower the t-case?
-Eric
Technohead is offline
