-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   4l60 or 4l80 in a yj (http://www.jeepforum.com/forum/f19/4l60-4l80-yj-1471544/)
ki4cye 01-30-2013 06:27 PM
81 Attachment(s)
I have a 90 yj with a 87 chevy tbi 350. Currently running an AX15 and 231j that is about 41'' long with a stock 6cyl drive shaft. Have a 3'' body lift and 4'' spring lift with factory axles for now. I plan on changing axles later, probably go with dana 44s. I am going to an auto trans soon,either 4l60 or 4l80. My question, is anyone running a 4l80 in a yj. If so how short is your rear drive shaft? If i run a dana 300 behind the 4l80 will i end up up with a decent length driveshaft and driveline angle. I would rather have the 80 but if its gonna eat u-joints Ill go with the 60. I cant seem to find where anyone has done a writeup on a 80 swap that posted how it turned out. If anyone has a link to a build please share. Thanks for any and all help.
leftlanetruckin 02-02-2013 08:56 PM
For your setup, a K case 700R4 or 4L60E is more than enough. Maybe why not many have bothered with the 4L80E?
You can then get a 231C HD transfer case and it will bolt right up to a 4wd 700R4/4L60E.
Martin
ki4cye 02-03-2013 11:17 AM
81 Attachment(s)
Ok thanks. What years for the K case 4l60. Ill be getting one soon. The local pick and pull has a sale going now. All transmissions $80 and all t-cases $30
leftlanetruckin 02-03-2013 03:10 PM
Hell, maybe 1990 and later?
There will be a massive letter K stamped in the side of it, cant miss it.
The 231C HD will have exactly that on the round tag on the back of it.
Martin
ki4cye 02-03-2013 05:02 PM
81 Attachment(s)
Thanks for the info. Hope to be going to get one friday
The time now is 03:36 AM.
