42rle shift kit install? - JeepForum.com
post #1 of 5 Old 06-20-2013, 11:22 AM Thread Starter
superjet86
Hello,
I need to change my fluid and filter on my 2009 unlimited. My question is if I am already dropping the pan should I install a shift kit to prolong the trans life? Thoughts?
superjet86 is offline
post #2 of 5 Old 06-21-2013, 04:25 PM
GilaMtnJeep
GilaMtnJeep's Avatar
There is only one shift kit I know of for the 42RLE, the A604 by Transgo. Unfortunately it will not make your trans last longer, but may help with firmer shifts.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 5 Old 06-22-2013, 08:17 AM
GilaMtnJeep
I should also point out if you do want to do something positive for your trans, add an external cooler and change the fluid when it's supposed to be. The two things that hurt the 42RLE the most are heat and improper maintenance.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #4 of 5 Old 06-22-2013, 09:30 AM Thread Starter
superjet86
I have been looking at coolers and I don't know if i should just spend the money and get one with a fan.
post #5 of 5 Old 06-22-2013, 10:29 AM
GilaMtnJeep
Here's a starting point.
http://www.jeepforum.com/forum/f9/au...etups-1466587/
And one mainly about the Derale cooler.
http://www.jeepforum.com/forum/f9/ke...ooler-1260191/
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
